BruceMc
Nov 07, 2019Explorer III
Continuing the updates: We purchased a pair of swivel table kits for the alter-abled as source material for this project:
When the kits arrived, they were missing some parts. As I was planning to cut them up, I had what I needed, but it was a bit frustrating to receive incomplete product. And the feedback mechanism left a lot to be desired - it was rejected, and once rejected, additional feedback could not be provided. Boo.
Using pieces of the kit and bed rail angle iron, I built new brackets for swivel tables, and modified the table tops, as follows:
Left and right brackets welded up & painted with hammered finish:
Assembly completed & painted:
Assembly complete, ready to bolt into place:
Fitted:
Bracket positioning - Note it hits the top of the arm rests. I drill new holes in the movable tube and re-positioned the height adjustment snap button so it would set just a tad above the arm rest.
Aft side:
I modded the backets on the tops so they would set lower on the brackets by removing the existing stud and welding in a nut.
Previously, they set about an inch above the square wall tubing.
I purchased two thumbscrews with 5/16 x 2" bolts to attach the tops to the square wall, then opened up the hole nearest the end to accommodate the increased bolt size:
Final Result: A set of tables that can be removed for storage, yet quickly and easily installed when needed:
We tested these on our summer trip/family reunion. We hauled our oldest daughter and her 4 & 6 year old kids, our grandchildren. They worked very well.
I plan to either cut up the solid surface (corian) tabletop I made for the dinette, or obtain more corian & custom make the tops. Corian is a bit heavier, but in the grand scheme of things, is much more durable than the bamboo. We might find the original bamboo tables are quite sufficient - time will tell.
To finish the seats, they needed permanent cup/phone/etc holders. The design was also intended to further stabilize the swivel table upright tubes, as they were a bit thinner than I would have liked.
Two openings are square, the center opening is a bit smaller in one direction. I used a variety of cup holders to size these boxes, and maximized the available space:
Initial fitting:
Initial fitting - I determined I needed a support panel/base for the right side, as the upright tube just didn't have the strength for decent stability:
Cupholder/support base finished and installed:
Left size install finished and installed. I used a screw clamp to hold the outer end to the upright and screwed the inner end to the pantry cabinet:
Once installed, I cut some of the "waffle" non-skid foam shelf liner material to fit the bottoms. These absorb some noise and keeps things from rattling around.
Project complete.
Next: Storage boxes behind, beneath the seats. (This project is complete, but I've yet to post the details)
As always, tons of photos of these projects are located at my photo hosting site:
https://pbase.com/brucemac/2015octsunseeker
Fitted:
Aft side:
Initial fitting:
Project complete.
