TNGW1500SE wrote:
Jsejmz09 wrote:
...........I forgot that even on a forum of great people, there has to be a few, well you know.
Hey if someone's a Jerk, just click on their name (to the left of their post) and block them. That's what I do. I don't have any need for their BS.
Now:
I'd add some device that kills the pump if the temp gets too high in the compartment.
Maybe: Sensor
Pushing air in would be better than pulling air out. That way your fan would not run in hot air.
I'd worry about the needle and seat in the carb being overpowered by the pump causing a rich mixture or worse a carb overflow while running. That generator would have been gravity feed from the factory. Your fuel pump pressure needs to be next to nothing.
More vent are not always better. It's all about air flow.
PS: I blocked two more members due to their reply's to you on this thread. I think that makes an even ten.
Okay, maybe I'm dumb but why wouldn't a gravity feed work in the first place? Why couldn't it be hooked up to the same feed line that the original one was? When I considered doing this that's what I was going to try.
