Gjac's avatar
Gjac
Explorer III
Jul 18, 2015
Replacement Board for a 6 gal WH
I am trying to find a replacement board for my 20 year old Atwood water heater. There are no part numbers left on it but I found a piece of paper that I wrote down when it was 10 years old. I believe it is a G6A-8E. Looking at the Dinosaur web site they don't cross reference the model numbers, but see a universal board USB. Does anyone know what is the correct replacement board? Also with the universal board I don't see the 6 pin connector that I have with my old potted board.( board has no continuity between the ground (green wire and power brown wire pin therefore bad).
  • You will need to compare your boards to these. First there is two sizes a small and large. Then there is different ignitor posts, one is a 1/4 quick connect spade and the other is like a spark plug connector.
    Dinosaur Boards
