nbargolf's avatar
nbargolf
Replacement CB antenna
We have a 2008 Fleetwood Providence 40x and I want to replace the CB antenna which is a 12' wire. I tried a 24' Firestick but the mount is totally different. Anyone done this replacement? Just need some suggestions.
  • Not sure what you mean, but the Firestik (and many other antennas) will use a 3/8"-24 screw-in base. If you're looking at a 12" flexible rubber antenna, it's probably designed for a handheld device and uses a BNC connector. Without more info, it's hard to tell.
    One other thing to keep in mind, though. Motorhomes are notoriously difficult platforms for decent radio operation, in part because the nature of their construction does not provide a "ground plane" for the antenna. The Firestik is specifically designed to mitigate this problem by using the base and coax as a substitute ground plane. Using any antenna that requires a ground plane on a motorhome, without modification, will almost certainly give you such abysmal performance that you might be better off with two tin cans and a very long string. :)
    If you can get some further information, post it here and I can maybe be more helpful.
    Skip
