Tom_M1
Jan 22, 2020Explorer
I have both a Winegard Sensar IV and a Jack. The Jack is mounted on a Winegard crank-up assembly. I camp virtually 100% in the boondocks, mostly in TV fringe areas. The Jack is useless for VHF stations. About 25% of the US TV stations are broadcasting on the VHF band so VHF is important. My Batwing is mounted on a separate mast and I use that for times that my Jack will not pull in the desired station. The Jack works well for UHF and most times that is all I need.
As Bill noted, the booster is inside the coach. You can not use this booster. If you use the Jack or Batwing, you must use the included power inserter.
38,769 PostsLatest Activity: Apr 24, 2002
