dodge_guy
Jan 22, 2020Explorer II
Tom_M wrote:
I have both a Winegard Sensar IV and a Jack. The Jack is mounted on a Winegard crank-up assembly. I camp virtually 100% in the boondocks, mostly in TV fringe areas. The Jack is useless for VHF stations. About 25% of the US TV stations are broadcasting on the VHF band so VHF is important. My Batwing is mounted on a separate mast and I use that for times that my Jack will not pull in the desired station. The Jack works well for UHF and most times that is all I need.
As Bill noted, the booster is inside the coach. You can not use this booster. If you use the Jack or Batwing, you must use the included power inserter.
I used the existing wall power booster. No issues.
38,769 PostsLatest Activity: Dec 31, 2014
