Bill_Satellite
Jan 22, 2020Explorer II
Tom_M wrote:
I have both a Winegard Sensar IV and a Jack. The Jack is mounted on a Winegard crank-up assembly. I camp virtually 100% in the boondocks, mostly in TV fringe areas. The Jack is useless for VHF stations. About 25% of the US TV stations are broadcasting on the VHF band so VHF is important. My Batwing is mounted on a separate mast and I use that for times that my Jack will not pull in the desired station. The Jack works well for UHF and most times that is all I need.
As Bill noted, the booster is inside the coach. You can not use this booster. If you use the Jack or Batwing, you must use the included power inserter.
Don't quote me. I never said that! Neither the Jack nor the Winegard has a booster inside (both use a power supply to turn on the booster inside the antenna. However, the Condorde does not have the amp in the head.
38,769 PostsLatest Activity: Dec 31, 2014
