TC_Z
Oct 16, 2019Explorer
Replacement of Trans Cooling Lines ??
Hi, we have a 2007 Winn Voyage 38J on a Workhorse W24 chassis with a 6-speed Allison transmission.  The transmission cooling lines are weeping in their flex section near where they attach to the transmission.  Doesn't drip best I can tell but I can see where fluid has stained other areas.  Appears I may be able to order the replacement lines; W0004928 & W0004929.  However, my questions are:
- am I able to replace these without further engine disassembly? Am I able to access the fittings to replace them?
- is there a transmission line "patch" kit so I could repair the weeping flex section without having to replace the entire line assembly?
- has anyone else had these leak? If so, what did you do?
