Big_Katuna
Oct 15, 2018Explorer II
7.5 is about all you will see.
The remotes. If the red led flashes when u push a button the battery is fine..
They have become unsynched.
Under the dash behind the swing out door drink holder thing, (has your hinges failed yet?) there is the remote lock controller. It has a led you can barely see and a push button you can barely get to.
You have to push the button (three?) times so fast it’s silly and get the led to blink or change colors (I forget), then you push the lock button on the remote.
Repeat for the other fob.
It lost synch so often I gave up trying to use it.
Got locked out once before I learned how unreliable it was.
Maybe you will have better luck.
There is also a 12V fuse panel back there.
