Big_Katuna
Oct 15, 2018Explorer II
I think the Starlight is bright enough. Much brighter than the stock light.
It’ left the factory as a 300. You could not order a 330 in an Expedition. If you wanted more HP, you would have to buy a Discovery or Excursion.
Someone might have tuned it up, which is not a great idea as the cooling wasn’t designed for the extra heat. Tuning didn’t change the torque.
You have an economy mode button on the trans. It changes the shift points in gently rolling hills.
5th and 6th are over drives and it doesn’t shift into 6th until about 63.
The good news is the MPG doesn’t seem to change much with headwinds or rolling hills or towing our 4000 pound car.
7.5 is what mine gets.
