1BryNelson's avatar
1BryNelson
Replacement Rear View Mirrors
Both of my outside rear view mirrors are wobbly and I can't find any way of tightening them. Does anyone know where I can find replacements???? I've looked on the internet, but only found one place; Velvac.com.
Any help would be appreciated.
Bry.
  • Side view mirrors . . . . I have not seen a motorhome with a rear view mirror. That is the one mounted in the center of the windshield.
  • Manual, electric, did you check the website for Velvac? Normally they will give instructions for adjustment or tightening. Look for a cap that removes, a screw or bolt will be under it. If it won't tighten, remove it and try a washer under it.
  • Velvac when I needed to replace inner large metal bracket that keeps mirror and housing from swinging in the wind. It was doing this after I backed out of driveway without moving my Honda Pilot first. Avoided the Honda Pilot, but neglected to avoid the large, tall, and unbelievably hard not to see pillar next to the driver's side window. I will never do that again!!!
