- dtucker3usaExplorerOk thanks I'll give it a try.
dtucker3usa wrote:
Doug, the dimensions of the microwave are 141/2H x 22"W X 15"D. then it also has the baffles to fill in the extra space on the top and bottom. It is the original microwave out of a 1997 Damon Intruder 352.
The Dometic should work. Doug- dtucker3usaExplorerDoug, the dimensions of the microwave are 141/2H x 22"W X 15"D. then it also has the baffles to fill in the extra space on the top and bottom. It is the original microwave out of a 1997 Damon Intruder 352.
- Your M/W is the standard small Microwave in RV's. Especially for built in. See Below. Doug
Microwave itself is 11 1/2"H x 21 1/2"W x 16"D Baffles add an additional 5.5" to the height if installed into a cabinet -
http://www.campingworld.com/browse/skus/index.cfm?skunum=70164&rewrote&affiliateid=5193&gclid=CLTF55D36dECFVGewAodcWABIA - dtucker3usaExplorertried that already. Most of the regular microwaves are either not big enough or if they would fit the length and height, they are too deep for the cabinet.
- TNGW1500SEExplorerTake a tape measure and check at Home Depot, Walmart, Best Buy, etc. I got mine at Home Depot. It fit right in but I couldn't tell you the size of it. I bet one of those places have something that will fit.
38,766 PostsLatest Activity: Jan 10, 2026
