wolfe10
Jun 24, 2018Explorer
Yes, if you got 12 VDC between the two small terminals with the dash switch ON, then the solenoid is bad.
If you do not have 12 VDC between the two small terminals, disconnect the one that should have 12 VDC positive from the dash switch and use a small jumper wire (small gauge is fine) from either large lug that is over 12 VDC to the small positive terminal. You should hear the solenoid click and read the same voltage on both large terminals.
38,782 PostsLatest Activity: Sep 19, 2026
