kemerExplorerNov 03, 2019Replacing HornI need to replace the horn on my 2014 Winnebago Sightseer. It's a Ford F53 Chassis. It looks like the power wires that go to the horn are of a plug and play type. Is this correct? If so, it seems lik...Show More
Sam_SpadeExplorerNov 03, 2019Yes, should be easy.Just study the old one a bit and get a replacement with the same number of electrical terminals and a similar (or adaptable) physical mount.Note: if you are getting one that is a LOT louder, a relay probably will be needed.
Related ContentReplacement Lights for TTHorn replacementAnybody Replace Their Stock Horn ?Replacing Horn - Want a LOUD OneFord E450 Horn replacement
