I need to replace the horn on my 2014 Winnebago Sightseer. It's a Ford F53 Chassis. It looks like the power wires that go to the horn are of a plug and play type. Is this correct? If so, it seems lik...
Now is the tome to install an air horn. I installed mine separate from the regular horn, but isn’t hard to wire into the OE horn wire to use the horn switch. Mine also came with a different horn. It’s a small air horn type. Sounds better than the OE horn.
