wa8yxm
May 04, 2016Explorer III
AGM's are among the class of batteries properly called Sealed Valve Regulated Lead Acid Batteries.. These are also called "Maintenance Free" meaning once they are initially "Charged" with acid/water mix you can not add later. If the batteries are hard to access. a good choice,, AGM additionall can be mounted on end, or sideways or other "Unusual" positions (no This side up) sticker
Otherwise they cost a bunch, and being "Sealed" and maintence free you can not replenish moisture that eventually boils off, this means they may not last as long as a properly maintained flooded wet cell. (Source, many web pages about battereies including the manufacturer's spec sheets for the batteries)
GOLF car batteries, specifically the GC-2 are very common in RVs.. You put two sis volt GC-2 Golf car batteries (Which are Usually flooded wet cells) in series you get 220-230 amp hours.. You can add DISTILLED water as needed (JUST below the bottom of the filler tube, not touching it) and they have an average life of 7-10 years properly maintained.
They also cost far far far far far less than AGM's and give you the most bang for your buck.
There is also a GC-12,, (12 volt golf car battery) but I do not know the specs on it.
I went with DEKA G-20s (A GC-2 class. 230 amp hours) when I replace my interstates... I would hate to try and wrangle 230 amp hours of 12 volt battery (A 4D would match that) as I could not even lift the G-20s. and I'm a big strong guy.. The assistant at the store lifted 'em and I slid 'em in place.
38,769 PostsLatest Activity: Mar 31, 2026
