robatthelake
Sep 15, 2013Explorer
In addition to the 2 Screws that Hold in from the Top Front there are also 2 Very Long Bolts that are hidden behind the Lower Front Grill.
These go up at a 45 degree * angle from front to back into the support bracket which is a Metal Plate behind the Microwave that is attached to the wall.
I found that a Rubbermaid Tote was the right size to fit under the MW on the Stove Top. This worked well to support the MW once the Bolts were removed.
The MW actually hooks onto the metal bracket so be prepared to lift it up slightly in order to get it away from the wall!
38,766 PostsLatest Activity: Jan 10, 2026
