charlestown's avatar
charlestown
replacing steering stabilizer on my class c rv
hello I have a 31ft coachman leprechaun and im told replacing the steering stabilizer would improve the steering and handling abit this is a 2014 with 7000 miles on it basically its a new rv on a e450 chassie but im feeling the wandering alittle heading down the highway. have any of you guys replaced yours , if so what kind did you go with and did it make a difference I sure would like to know before I order one . thanks mark from Charles town wv
  • Recent Testimonial
    Reply Post by 2kGeorgieBoy
    Re: Wandering at highway speeds
    Reply #36 on: March 14, 2018, 09:07:02 PM
    START QUOTE:
    Jeff..Although we have a 2000 Georgie Boy 31' Maverick "C" on a Ford E450 chassis, I can fully agree on the caster effects, at least for us. When we got the unit in Jan 2014, the dealer had us take into a truck shop for an alignment. It turned out OK....A trip to Moab shortly there after brought out the problems. I then started reading the threads and comments here about the caster settings....esp., from Harvard. I checked the data from the first alignment and found that it was set at about 3 1/2 degrees positive...about in the middle of Ford's recommended range. Shortly before a cross country trip to Maryland in fall of 2016, I returned to the shop where the first alignment was done. I talked to the service manager and he knew of the problems with the E450's and was happy to increase the caster as I asked. The alignment tech was also familiar with it and ended up with settings close to 5.5 degrees positive. WHAT A DIFFERENCE! The unit tracked straight down the road, passing semis no longer caused a white knuckle hold on the wheel, and overall it was just a lot more enjoyable. It did however increase steering effort a little but not anything to worry about. But, be sure that the shop you go to is willing to "think outside of the box". Our first alignment was "plain vanilla", right in the middle like it was always done. Second time out, they were very willing to increase settings beyond what normally would be done, and still stay with in Ford's guidelines (0-7 degrees, I believe). I realize that our E450 chassis is an entirely different animal than yours, but I was trying to add support to the caster increase thinking and how it helped us......if you go down that road.
    END QUOTE:
  • You have too little +caster for highway speeds.
    Ford ships these E350/E450 Cutaways off the assembly line
    with +3 to +4 degrees of Caster. Those settings are
    OK for city driving BUT you want to have +5 to +6 degrees
    of Caster for highway driving, OTHERWISE:
    POPULAR MECHANICS MAY 1973:
    START QUOTE:
    If too little caster exists, the car will wander and weave,
    thus necessitating constant corrections in steering.
    END QUOTE:
    There are at least two ways to increase the effective
    runtime caster:
    1. Decrease the tire inflation pressure to the required
    minimum for load (to increase Pneumatic Trail), and or
    2. Increase the caster angle during an alignment
    (to increase caster trail).
    If you find an improvement in reducing the tire pressure
    you will be amazed what it is to add +2 degrees of caster. IMO.
    The specified range of Caster for the E350/E450 is
    from +1.5 to +7.0 degrees. As you can see
    almost any possible setting is "within spec"
    for the "tweak the toe and you are good to go"
    alignment services. Stay away from Ford
    dealerships and have it done at a "good"
    truck front end shop".
    Caution, "You may need to teach a new dog old tricks."
  • I put Steer Safe on my Class C and two Class A's. Yes, it made a big difference to me.
