tkcas01
Jul 31, 2013Explorer
I've never done this, but I see a couple of options. If they are ducted, you might be able to run new wiring through the ducts. Another approach might be to remove ceiling light fixtures and/or speakers. This should give you access to any dead space between your roof and ceiling. You could then use a snake wire or other improvised tool to route the wires using the openings as access points. Depending on how things are configured it might not be too bad.
38,783 PostsLatest Activity: Sep 09, 2026
