JimM68 wrote:
Any info - details - pictures - links is appreciated.
First, make sure you check you
current fridge manual for install dimensions. This should help you select a replacement.
If you haven't already done so, check out possible fridge replacements at
www.appliancesconnection.com. You can specify height & width to narrow down your choices.
Finally, you may need more than your forklift. Your current fridge weighs over 300 pounds and manhandling it could be prolematic.
Consider having it installed. I did. Here's
my fridge install.
