Thanks guys!
Dometic "recess dimensions" from the install manual:
height: 63 3/16
width: 32 3/4
depth: 26 1/16
I had the freezer open too long yesterday redoing my icemaker install.
Freezer is 16 degrees... :(
Fridge is 33.
I'm making a good amount of ice, and no longer dribbling water all over :)
Bullydogs, you have the same floorplan, same fridge in the same slide as I do. And yours works like mine used to. Sure wish it would again, itsa good unit and works well for us. or did.
Don, have you done one in a slide?
This height issue is really screwing with my head.
Especially since I have seen with my eyes a samsung RF220 in "my coach"
I really really really should have paid more attention. That fridge is almost 71" tall!
I've measured 10 times, even if I remove the slideout adjuster completely and trim the top to the limit I can't find even a tick more than 70 inches
I do have my rear fans on a switch and running continuously.
I've never opened up the burner area, and do not currently have access to a decent ladder to get at the top vent, though I could pull the picnic table over and put my stepladder on it.
Is there anything to be gained in there?
