ricelake922's avatar
ricelake922
Resolution to previous post 're fuses not working
A couple of weeks ago I posted that my 1996 Monaco Dynasty RV had fuses that were showing no power to fuses but the accessories were working such as dash fans and side step. I took the RV to a company who I have used before and are excellent with electrical issues. The outcome is there is no power going to the fuses and before my time of owning the RV is the power to these fuses has been rerouted and the only way to find out where and to what power source is to follow the wire attached to the dash fans for instance to find their power source. Interestingly the accessories attached to these "phantom power" only works when the kill switch located at the door of the RV must be on for these accessories to work. Any thoughts on this issue is very much appreciated. When I go to Florida this winter I will spend some time to find the power source by following the lines associated with the accessories. Yes...I fully expected the wires are attached to the kill switch and powered by the chassis battery but I would like to find out if this is the case.
