femailyetti's avatar
femailyetti
restoring 1987 holaday Rambler
I have purchased a 1987 Motor home and am fixing it up as money is available. I have replaced the passenger side brake line and caliper and now have three wheels that lock up when you stomp on the breaks. This is much better then the one or two that were working on the harrowing drive home after the purchase.
The air pumps are being removed at this time as the driver side one is locked up. The passenger side one seems to be working, but there is a hole in the part mounted on the header that is causing a little ticking sound. The header parts will be welded up at a later date when I can bribe my people with a appropriate reward.
I have changed the passenger side spark plugs, the old ones had a gap of around 80 to 85 thousand when I took them out. They did have a nice tan color. The driver side plugs will be replaced next, along with the cap and rotor.
The front air bags are holding pressure, and the front suspension has been greased with new grease. It has some sort of stabilizer made from mounting two large springs on the front and rear of the lower control arm.
I will be asking some ???? when I get to the parts I don't under stand.
