Lou_R's avatar
Lou_R
road warrior generators
Fellow Road Warrior owners, I would check the support brackets for the generators. I was on the interstate in Sacramento when suddenly
the generator fell down in the compartment, barely above the road. I was able to call a mobile welder to come out and reweld the brackets.
His inspection reviled that the angle iron was cut off to make it easy to weld to the front bracket, making the tab a flat iron instead of an angle bracket. I would suggest that you inspect the brackets and if the same as mine have new tabs welded for support. It is not a matter if they will break it's when will they break. The generators are very heavy.
1 Reply
  • Good point. Thanks for the reminder.
    It's something else to look at during maintenance checks.
