kdk
Nov 21, 2018Explorer
Mike, I have a hard top with removable panels above the driver and passenger. We have been in driving rain where we had to pull off the road. No leaks, quiet to ride in with no wind whistle either. If you have a soft top I could understand some leakage, but not with a hard top. An idea for you to try and find the leaks in hard top would be to pressurize the interior cabin. The cabin is vented to the outside thru the rear door. If I remember correctly a one way flapper would have to be taped open to the position. Then hook up a shop vac with the hose coming off the exhaust giving pressure. Tape this hose to the vent behind and under th spare tire rack. Turn on the vac and pour soapy water over the jeep and look for bubbles. Now that you found the source of the leak fixing it is your problem. Only idea would be black silicone. Good luck.
Blessings; Keith
Blessings; Keith
