ct78barnes
Jan 01, 2014Explorer
Thanks Dave
That is what I thought because they do have a second car kit and this would be like I still had the Trailbalzer and got the second car kit.About the 12 volt socket we are having one installed a long with the fuse minder so we will have a switch so we do not have to pull the fuse 32 and a new plug installed for power for the Even Break. When you pull the key or open the door you lose the power to the 12 volt power points. It is a pain with the Garmin because it has to be rebooted every time you stop. Why did GM do this my 2006 Trailblazer had power all the time. the Equinox shuts all power to the 12 volt ports in the front. They have one in the trunk that stays hot all the time but what good would that do if you wanted to charge your phone or any outher device.
38,782 PostsLatest Activity: Sep 10, 2026
