Kidoo's avatar
Kidoo
Roadmaster Kwikee level best Jacks sensorsr broken
Hi, my jacks are not working and I found a yellow wire broken at one of the front jack sensor and one broken sensor at one of the rear jack.
Is it possible to reconnect the wire to the sensor, it seems to be broken just where the wire goes in the sensor and can we get just the sensor itself, order online?
Thanks
  • Kidoo wrote:
    enblethen wrote:
    Page 8 shows part number for the proximity sensor.
    Power gear/ Kwikee
    Yes, you could splice back onto the sensor if you have enough wire to do so. I would recommend soldering and heat shrink.
    This is not the same as mine, I have the jacks legs that retracts 90 degree.
    That's why you need to email PG and ask them the P/N and where you can get the switch. Doug
    Power gear/ Kwikee
  • Page 8 shows part number for the proximity sensor.
    Power gear/ Kwikee
  • You will have to email Powergear/Kwikee and ask them if they still have parts for your system. They do not sell to retail customers but only thru authorized Powergear dealers. Doug
    PG.info@lci1.com
