What's the consensus on how much distance on level ground between the road and the bottom of the rock guard assuming it's a solid rubber piece and not the brush type?
If your rock guard touches the ground, it will kick up rocks as you're going down the road. 5 inch clearance on level ground is what you're looking for. Any closer and you're going to defeat the purpose of having it. If it's all the way at the back of you're MH, the height my vary significantly when you're loaded and ready for travel.
