What's the consensus on how much distance on level ground between the road and the bottom of the rock guard assuming it's a solid rubber piece and not the brush type?
If you read the installation recommendations for the Ultra-Guard, you'll see they recommend 4-1/2 to 5 inches of clearance between the bottom of the flap and the ground.
If it drags, it will certainly pick up rocks as you drive along.
