time2roll
Aug 11, 2016Nomad
Did you look for the freeze sensor? Was it in the ice or was it poorly installed so it would fall away from the evaporator?
While you are in there check the air plenum divider on the inside. Very common for this divider to be poorly installed and allow chilled air to circulate back into the machine instead of directed out to the RV.
38,763 PostsLatest Activity: Dec 05, 2025
