Hi all, My 95 bounder went through the Los Cabos hurricane and blew out most of my windows as well as all the vents , covers and ac shrouds. My concern is that the roof now is down to the wood. Looks...
If not insured, the old plywood should come off. If you elect to use the old plywood you will still need to cover with luan. Apply dicor glue or comparable to the luan then gradualy lay down the new EPDM roof material. If you check dicor's web site there will be a lot od good advice.
