dougrainer wrote:
You may not agree, but the difference is I am a PROFESSIONAL ...
A professional of / at WHAT? There is no such thing as a "professional" roof replacer.
In narrow usage, not all expertise is considered a profession. Although sometimes referred to as professions, occupations such as skilled construction and maintenance work are more generally thought of as trades or crafts. The completion of an apprenticeship is generally associated with skilled labor or trades such as carpenter, electrician, mason, painter, plumber and other similar occupations. A related distinction would be that a professional does mainly mental work, as opposed to engaging in physical work.
So whereas you may have installed many ..??.. new roof coverings on RV/s you are by no means a professional
