My 1994 Holiday Rambler Imperial with a Aluminum roof has the thick tape down the center of the roof. But it looks like its getting soft and maybe even water under it. What should I do? peel it off an...
If you can't remove the old tape, cut off any loose tape, clean, and recover with wider eternabond tape. I had to do that to the slide top on my Holiday Rambler.
