oldave wrote:
Mike , Did you order a new thermostat too ? I'm pretty sure your old
one will not cooperate with the new units . The new thermostat is plug
and play same as the old one .
Your old thermostat may be worth more to someone than the old A/C units .
Measure the spacing of the 4 long bolts . Mine was slightly different
by just a small amount and I didn't know it , caused me a little grief.
I had to enlarge the holes where the bolts pass through a little .
Good luck
Thanks for the tip. I did get a new thermostate also.
