pb24's avatar
pb24
Rotors and Brake Pads
2007 Winnebago sightseer 35J on a W22 chassis. Both front rotors have a big crack are are going to need to be replaced. Does anybody have any experience with Brake Performance products? There rotors are cross drilled and dimpled and is supposed to help with cooling and stopping.
  • Unless you have specific issues with your brakes, I would stick with the OEM pads and rotors. Just because a rotor is cross drilled/slotted/dimpled (whatever really) and designated as "high performance" and/or "racing" doesn't imply that it will work better with your specific application. (unless you are racing your Class A RV)
    Chum lee
