usersmanual wrote:
mikim wrote:
Weigh your rig....tires will probably need to be inflated to 80 or 85 PSI. Anything higher will increase the ride harshness. Some info can be gleaned from this website http://www.hendersonslineup.com/.
Had work done on our 36 Allegro Open Road and made a huge difference. Expensive, but much cheaper than a new diesel.
most likely is(cheaper) but its still not a diesel pusher and no matter how much you spend it never will be one. The ride will be harsh no matter what .its the design of the suspention.
I bet a Keldeman system can come pretty close to it. And one would not have all the very high maintenance cost associated with a diesel pusher (most of them are under powered anyway).
Diesel chassis are pretty simple, and there is no reason why one could not achieve a similar ride quality with a gasser.
