ok marine grade pressure treated plywood i do not see any issue with that as i know pressure treated plywood is pretty much immune to rot unless its outside exposed to the weather and the lauan plywood has me a bit worried as i have used this stuff before for backs of cabinets its not very strong and it warps quite a bit unless its well secured to a rigid frame now the fiberglass they apply to it might help with keeping moisture out of the wall but this seems like a not so great choice if it works it works like somebody said the delaimnating issue on the outside most of the time now i am not worried about a flood just maybe steaming up the shower and opening the bathroom door and going to bed or maybe a cooking mess involving a spaghetti water spill its a full time lived in home not a get away what can be done to seal things up if need be i have read about the sewer solution malfunction with the presure release vent valves flooding out a coach my boss wants to use the sewer solution on his coach so we have to either account for this possibility or use a different product now at point does water become a problem is a long hot shower a problem is spaghetti water a catastrophe 6 months after the fact even if its wiped up right away or is none of this an issue
