jmarhmar's avatar
jmarhmar
rubber seal around windows
The rubber around the windows of my Georgieboy Pursuit keeps shrinking . Now I have a space between the ends of the seal. Can this be stretched back to length? Where can new rubber seals be purchased? Are there any other 'fixes'?
Any help will be appreciated.
Thanks,
John
1 Reply
  • Several years ago the windshields on our 96 Southwind were leaking and pulling out of the frames.
    I had both windshields reset, they used the original rubber gaskets and sufficient sealant.
    The shop that did the work said, not enough sealant was used when the windshields were installed at the factory.
    No leaks or windshield pop out since they were reset.
    Maybe you should consider having the passenger windshield reset?
    Possibly they were not installed properly at the factory.
