msturtz
Aug 09, 2018Explorer
We use it regularly if the dash AC can't keep up. This can happen if the coach is sitting in the sun for too long or the humidity is too high. It's a bummer I can't use both ACs while driving :( however, it is usually ok it just takes longer to cool down. Our QD6000 generator can't run both 13,500 BTU ACs. I'm thinking of installing an Easy Start unit to see if that helps. I do know both of my ACs won't run on a 30 AMP shore power connection the coach draws just a little to much power if you factor in other loads.
