dougrainer
Mar 16, 2019Nomad
You need to check and get back to this forum. Are there 2- 120 receptacles behind the refer? Monaco when the original RV refer was optioned, IF it had the optional refer Icemaker, they ran the Icemaker power from the 1500 watt Inverter. One Outlet is Inverter driven and the other is to regular Shore Power. If so, you just connect the new refer to the Inverter plug. IF NOT 2 Plugs. All you have to do is move the Refer receptacle BREAKER wire to the Inverter side of the Main Breaker panel. Doug
38,763 PostsLatest Activity: Dec 05, 2025
