I have an Holiday Rambler Admiral SE 2003, this week water was leaking inside from the air conditionner(top roof) (Dometic Duo-Therm) Does somebody know what is the problem? Thanks yves1956
This week, I assume you were not using the A/C.. Thus it's the roof seal... Or the covers are broken (not likely)
IF you were using it,, Then it could be dirty intake filters (Hot air return) inside the RV.. IT could also be improper leveling of the rv.. But again only if it's in use.
