I give up. My Class A Ford battery is dead. I was having a problem iwith my battery dying in storage, so I brought it in to an auto parts store and found out it was weak. Installed the new battery an...
The ECM (engine control module) draws power all the time, unless you have a chassis battery disconnect switch. Our MH, like yours I guess, only charges the coach batteries when plugged in to shore power and no chassis battery disconnect. Disconnect the negative cable on the chassis battery or get a Trik L Start, Amp L start that will charge the chassis battery from the coach batteries when on shore power.
