dougrainer
May 27, 2022Nomad
Under the step at the 4 wire connector is a YELLOW wire. THAT wire must have 12 volts when Ignition is ON. IF it does NOT, then that fuse is blown ands usually located at the LF fuse panel in front of the LF tire in that compartment. The Yellow HOT wire is what tells the step to retract when engine ON and the entry door closed. The entry door MUST be closed for the Ignition override to work. Doug
