wa8yxm
May 29, 2022Explorer III
Ok look for a 5 amp fuse.. If you have a Intelletec Battery Control Center I'd start there.. I like to use a test light to test blade fuses.
Ground the clip and touch the tip to both windows.
For this test the ignition will need to be in the ON position (Engine need not be running but ignition in ON)
Bright Bright - Fuse good
Dark Dark - No test (With the ignition ON this should not happen)
Bright/Dark or Dark/Bright Fuse blown.
if you do not have an Intelletec Battery Control Center check every fuse block/box/holder you got.
