Blaise
May 29, 2022Explorer
Geez, Winnebago made this task a bit harder. The step motor side of the 4-wire connector has 4 wires that lead to the step control module: red, white, yellow and brown ... very sensible. The wire for the ignition override is the yellow one.
But the vehicle side has 3 yellow wires and one white! So if I follow the loom and find the source of the bundle, it'll be a bit harder to determine which of the 3 yellow wires connects to the yellow ignition override wire on the control module. I'll have to use a continuity tester ... likely with a very long lead! :B
