glennrichone's avatar
glennrichone
RV Tires
I have a 2020 Newmar Bat Star. I’m coming up on 5 or 6 year old tires. I currently have: 235 / 80 R22.5 XRV
Michelin. Do anyone have a recommendation on other tire brands I can look at that will have the same ride, quality, and comfort as Michelin tire?
  • I don't believe that Toyo has an exact match in size to the Michelin tires you are currently using. If you do go with Toyo, be aware that the size difference will impact the accuracy of your speedometer and odometer.
  • I traded in my Michelins for Toyos a couple years ago, and could not be happier. I did find however Toyo does not have a tire the same size as the Michelins, at least in my case.  Have your tire person help with either going up or down on size.
    • glennrichone's avatar
      glennrichone
      Thanks, I will look into Toyo tires, and I hope they have a tire size close to what I have a 31 ft motor home with (235 / 80 R22.5 XRV). Thanks again for the info. Are happy with the ride the Toyo tire give and handling?
  • Hi,
    My tire person suggested Toyo. I'm extremely happy with them.
