way2roll
Dec 19, 2018Trailblazer
I guess some variables are needed here,
What is the demand - what needs to be run?
And what size is the Genset in the rv?
My point was, there are so many variables that a blanket answer won't do. Because as power demand goes up, configuration changes. Running a fridge only requires a decent extension cord,but running an electric furnace in 20 degree temps in resistance heat mode is an entirely different matter.
And as others have stated - do NOT backfeed the panel. I had a friend who was a lineman explain to me the risk associated with that. If you are going to wire to the panel then use a decent transfer switch at a minimum and a sub panel wouldn't be a bad idea.
Like all things, if you throw enough money at it you can solve any problem.
Personally I would just move into the RV until power is restored. Simple and cheap. Provided you mitigate the risk of pipes freezing.
38,768 PostsLatest Activity: Mar 27, 2026
