turbojimmy
Dec 19, 2018Explorer
way2roll wrote:
I guess some variables are needed here,
What is the demand - what needs to be run?
And what size is the Genset in the rv?
My point was, there are so many variables that a blanket answer won't do. Because as power demand goes up, configuration changes. Running a fridge only requires a decent extension cord,but running a furnace in 20 degree temps in resistance heat mode is an entirely different matter.
And as others have stated - do NOT backfeed the panel. I had a friend who was a lineman explain to me the risk associated with that. If you are going to wire to the panel then use a decent transfer switch at a minimum and a sub panel wouldn't be a bad idea.
Like all things, if you throw enough money at it you can solve any problem.
Personally I would just move into the RV until power is restored. Simple and cheap. Provided you mitigate the risk of pipes freezing.
True - it was a wide open-ended question. Lots of variables, and lots of options (some safe, others not so much).
The achilles heel in most cases is access to gasoline for the generator and propane for the RV furnaces. I found this out the hard way during Super Storm Sandy. After that experience - no power for weeks and no access to fuel - I converted my generator to natural gas/propane. NG is default and if for some reason that gets interrupted I have a 1,000 gallon propane tank (which is currently near empty, but the plan looks good on paper).
38,768 PostsLatest Activity: Jan 26, 2021
