usersmanual wrote:
braindead0 wrote:
We camp often in 100+ temps, no smell.. no chemicals necessary.
BS you get a 75 gallon holding tank 3/4 full in 100 degree heat and it smells. just have someone flush the toilet and stand below your vent pipe.
Other than a quick whiff when toilet if flushing NO Odors.
Black and grey waste tanks have 'vapor barrier' installed
'P' Traps (water), Air Admittance Valves (mechanical), toilet bowl seal (water), toilet floor flange gasket (mechanical) and vent lines that go out top of roof.
Same kind of system a S&B uses..and no odors either.
If you can smell the waste tanks then something is not working properly.
Find it/fix it..instead of mask it with chemicals (then you just have chemical poop smell)
