Old-Biscuit wrote:
usersmanual wrote:
braindead0 wrote:
We camp often in 100+ temps, no smell.. no chemicals necessary.
BS you get a 75 gallon holding tank 3/4 full in 100 degree heat and it smells. just have someone flush the toilet and stand below your vent pipe.
Other than a quick whiff when toilet if flushing NO Odors.
Black and grey waste tanks have 'vapor barrier' installed
'P' Traps (water), Air Admittance Valves (mechanical), toilet bowl seal (water), toilet floor flange gasket (mechanical) and vent lines that go out top of roof.
Same kind of system a S&B uses..and no odors either.
If you can smell the waste tanks then something is not working properly.
Find it/fix it..instead of mask it with chemicals (then you just have chemical poop smell)
But that's describing a grey tank. A blank tank vents directly out the roof vent.If you care to read my post I very clearly described scenarios where you will, can and do get Blank tank odor
IF you seriously believe that a blank tank 1/2 or 3/4 full has no odor then your delirious. If you can smell the black tank its because
its getting filled up and 1) bathroom vent is open and its in the same vicinity as your roof vent or your sitting around the picnic table and theres a invertion(wind swirling) among 2 examples of several reasons that all can happen even though the blank tank is so called working properly
The worst times one gets wiffs out the vent is when its getting full and its breezy and hot out or when I have noticed it when dumping as it vents out the roof vent ihave got the odd wiff
all of this depends on how full the tank is. all of my experiences have been when the tanks more than 1/2 full
Grey tank I have not had such experiences but I leave my grey open
so no build up.Your not "masking" anything with holding tank chemicals
there sold and used for a very good reason
